Will the volume corruption or data loss occur if one or more RAID expansion enclosures are disconnected due to hardware failure, power outage, or the fallout of the SAS cable?
Applied Models:
Answer:
The RAID expansion enclosure will enter the missing mode when disconnection occurs, and read/write IO access will automatically be blocked to avoid data crashing.
Release date: 2013-11-29
Was it helpful?
