Why can I not play videos using VLC player when using an SSL connection?
Applied Models:
Answer:
VLC player only supports SSL connections that have a valid certificate. If you do not have this, you will need to use a non-SSL connection to play videos using VLC player.
Release date: 2014-12-15
Was it helpful?
17% of people think it helps.
