What is myQNAPcloud? What is the difference between myQNAPcloud and MyCloudNAS?
Applied Models:
Answer:
MyQNAPcloud is a cloud service provided by QNAP for you to remotely connect to your Turbo NAS. Through this service, you can set up your own unique URL to connect to your Turbo NAS. With the easy-setup myQNAPcloud wizard, it’ll automatically configure port forwarding on your UPnP compatible router for your myQNAPcloud URL. With myQNAPcloud, you can stream, share, view, and download all your files remotely either on your phone or on any browser. To learn more, please visit: www.qnap.com/i/in/family_apply_v2/con_show.php?op=showone&cid=6#f5_01
MyCloudNAS is QNAP’s service for firmware versions lower than QTS 4.0 and acts also as a cloud service. With myQNAPcloud, users are provided with a myQNAPcloud ID (QID) and can log in and access their files through www.myqnapcloud.com.
To understand more about how to remotely access your Turbo NAS? Please visit the topic: “How to remotely access files on your QNAP NAS.
If your router does not support UPnP, please refer to: "If I don't have a router supporting UPnP, can I still use the myQNAPcloud service?"
Release date: 2013-07-29
Was it helpful?
89% of people think it helps.
