How many wireless devices can I connect to a QHora-301W router?
QHora-301W
Answer
Any radio frequency (RF) connection between your router and client device that supports Wi-Fi can create a wireless connection. Each peer-to-peer connection can consist of several connection sessions.
You can establish upto 64 wireless connections using both 2.4 GHz and 5 GHz wireless networks on your router simultaneously.
