How do I troubleshoot when my NAS keeps restarting after adding or replacing memory?
Last modified date: 2025-11-17
  • All QNAP NAS models
Symptom
After adding or replacing memory modules in your QNAP NAS, the device may fail to complete the boot process or repeatedly restart without powering up fully.
Solution
  1. Check memory compatibility:
    • Ensure that the memory modules are compatible with your specific NAS model.
    • Make sure you are using a certified QNAP memory module. Using third-party or uncertified memory may cause instability.
  2. Reseat the memory modules:
    • Power off the NAS and disconnect it from the power source.
    • Open the NAS chassis as instructed in your NAS hardware manual. (Consider using an anti-static wrist strap and handling memory by the edges.)
    • Remove and carefully reinstall the memory modules, ensuring they are securely seated in their slots.
    • Reconnect the power and attempt to start the NAS.
  3. Test with original memory:
    • If you replaced existing memory, reinstall the original modules and attempt to power on the NAS.
    • If the NAS powers on normally, the new memory may be incompatible or faulty.
  4. Perform a memory test on the NAS:
  5. Contact QNAP support:
Note: Most user guides do not provide detailed memory troubleshooting instructions. For model-specific hardware steps, refer to your NAS model’s hardware manual or the QNAP support website.
Further Reading
