Why does Multimedia Console display an “Unable to access volume“ error when the system volume is normal?
Last modified date: 2025-04-17
Multimedia Console
Scenario
When starting Multimedia Console, the system event log records the following error. This occurs even though the system volume is normal.
[Multimedia Console] Failed to enable Multimedia Console. Unable to access volume.
Explanation
Despite a normal system volume, Multimedia Console will not launch if any other volume is abnormal (e.g., degraded, read-only, or read/delete). All volumes must be in a normal status to prevent data loss.
Solution
To resolve the issue, you need to restore all volumes to normal status. For instructions, see What does it mean when a volume status is "Read/Delete", and what can I do?.
Further Reading
