After updating my NAS firmware to QTS 4.3.0, files cannot be synchronized from a Mac using Qsync Client 2.0.2. How can I fix this problem?
Applied Models:
Answer:
QTS version 4.3.0 or later is not compatible with Qsync Client 2.0.2 or earlier. We recommend updating Qsync to the latest version.
Release date: 2017-01-16
Was it helpful?
