Will resizing a volume delete my data?
Last modified date: 2021-07-02
Answer
Resizing volumes won’t affect existing data in the data volume,the data will stay intact after the process.
Note: Shrink a volume will need to stop all the services, you can't access the data at that time.
73% of people think it helps.
