Why is QVR Pro unable to connect to Foscam cameras?
QVR Pro, QVR Elite
Details
After connecting a Foscam camera, its status will be stuck on Connecting. This is due to some Foscam cameras using port 88 by default for RTSP and HTTP after its firmware update.
To fix this issue, edit the channel's Connection settings to use port 88 for both Port and RTSP Port.
