Can I configure a direct VLAN connection between a QHora router and a computer without using a switch?
Last modified date: 2023-02-13
  • QHora-301W
  • QHora-321
  • QHora-322
Answer
Yes, you can set up a direct VLAN connection between a QHora router and a computer without a switch connection.
  1. Configure trunk mode on the router.
    1. Log into QuRouter.
    2. Go to Network > WAN & LAN Settings.
    3. Identify a LAN port.
    4. Under Action, click .
    5. Select Trunk mode as the VLAN mode.
    6. Select one or more VLAN IDs.
    7. Specify a port description.
    8. Click Apply.
  2. Configure the same VLAN ID on a network adapter on your Windows or macOS computer.
    Note
    Check the web help or user guide of your computer's operating system to configure the VLAN settings on network adapters on your computer.
42% of people think it helps.
Har du stadig brug for hjælp?
Stil dit spørgsmål i QNAP Community. QNAP-medarbejdere og erfarne brugere svarer.
Spørg communityet
