Can I bind a Virtual Switch to a Wireless WiFi network card?
Last modified date: 2023-03-20
  • All NAS Series
  • QTS 4.4.1 or above
  • Network & Virtual Switch
Limitation
It is not possible to bind a virtual switch to a wireless WiFi network card, such as the QXP-W6-AX200.
For this reason, it is also not possible to create a docker using Bridge mode on Container Station, if the NAS only uses the WiFi network card, as a virtual switch needs to be created.
Further Reading
How to use and set up your Network & Virtual switch?
75% of people think it helps.
      Chat med os! Chat med os!
