How to use speakers when using QBoat Sunny- An LXC example
In this tutorial, you will learn how to use speakers with QBoat Sunny.
You will need to create a Ubuntu LXC container. For more information on setting up containers, read the tutorial at https://www.qnap.com/go/how-to/tutorial/article/how-to-use-container-station
Setting the LXC Container
  1. Go to the Container Settings of Ubuntu LXU container, and click "Advanced Settings"
  2. Click "Device"
  3. Click "Add"
  4. Choose "Sound and ALSA (14,116)"
  5. Click "Apply"
  6. Open File Station
  7. Go to the location where your Ubuntu LXC container is stored (for example: "/Container/container-station-data/lib/lxc/<ubuntu-trusty-1>")
  8. Open "config" in a text editor.
  9. Enter the following line at the bottom of "config":
     lxc.mount.entry = /dev/snd dev/snd none bind,optional,create=dir
  10. Save (and overwrite) the "config" file in the location where your Ubuntu LXC container is stored.
  11. When you reopen your Ubuntu LXC container you will be able to use the speakers.
Datum vydání: 2017-12-29
Bylo to pro vás to užitečné?
Děkujeme vám za vaši zpětnou vazbu. Máte-li nějaké dotazy, kontaktujte prosím adresu support@qnap.com
100% lidí si myslí, že to pomáhá.
o
