Why is my NAS status incorrectly reported in Q'center?
Q'center
Symptom
In the Q'center server list, the status may display Agent has problem, Q'center agent is abnormal, or list your NAS as Offline.
Recommendation
There are several possible causes for these issues:
| Cause | Fix |
Your network firewall is blocking ports 6600, 6606, 6621, or 6623. | Configure your firewall settings. |
Your network is heavily congested or has limited capability for handling multicasts. | Check your network and related router settings. |
The IP address has changed for Q'center or the managed NAS. |
The NAS is functioning abnormally, and the Q’center Agent has become unstable. | Disable the Q’center Agent
Note This action will remove all historical records for the managed NAS.
Q'center Agent is unable to send or receive data normally because the managed NAS is under heavy CPU load (> 90%) or has limited network bandwidth. |
Stále potřebujete pomoc?
Položte svůj dotaz v komunitě QNAP. Odpoví vám pracovníci QNAP a zkušení uživatelé.
