The Turbo NAS does not power on after I press the power button. What should I do?
Applied Models:
Answer:
Remove all the HDDs, make sure the power cable, power adaptor, and the power supply unit are connected correctly and the power supply is normal. If the problem persists, contact your local reseller or distributor for repair or replacement service.
Datum vydání: 2013-04-19
Bylo to pro vás to užitečné?
Děkujeme vám za vaši zpětnou vazbu. Máte-li nějaké dotazy, kontaktujte prosím adresu support@qnap.com
20% lidí si myslí, že to pomáhá.
