Hybrid Backup Sync (HBS 3 version 24.0 or later)
Hyper Data Protector (version 2.3.0 or later)
NetBak PC Agent (version 1.3.0 or later)
Details
In Hybrid Backup Sync (HBS 3), Smart Versioning works by creating regular backups and retaining them for a specified length of time. When configuring Smart Versioning, you need to set time periods for several different settings.
| Setting | Description |
| Number of hours to retain the latest version of the hour | The latest backup created that hour becomes the hourly backup. The backup is retained for the specified number of hours before being removed.
Note This setting is not applicable to HDP. Currently, HDP does not support hourly smart versioning retention. |
| Number of days to retain the latest version of the day | The latest backup created that day becomes the daily backup. The backup is retained for the specified number of days before being removed. |
| Number of weeks to retain the latest version of the week | The latest backup created that week becomes the weekly backup. The backup is retained for the specified number of weeks before being removed.Note For this setting, a week starts on Monday 00:00 a.m. |
| Number of months to retain the latest version of the month | The latest backup created that month becomes the monthly backup. The backup is retained for the specified number of months before being removed. |
| Number of versions to retain before applying the above settings | This setting determines the minimal number of versions to retain before any of the above settings are activated. This setting can help you ensure that when an hourly, daily, weekly, or monthly backup is removed at the end of a specified period, the system does not accidentally end up with no backups at all. |
Note
If the frequency of the backup schedule is greater than the period of a setting, then that setting will not apply. For example, Number of hours to retain the latest version of the hour will not take effect if the backup schedule is set to Daily, no matter what value you specify for this setting.
For example, let’s imagine that we scheduled backups to run daily at 3:00 am starting on Jan 1, 2024, and configured the Smart Versioning settings as follows:
- Number of hours to retain the latest version of the hour: 24
- Number of days to retain the latest version of the day: 7
- Number of weeks to retain the latest version of the week: 4
- Number of months to retain the latest version of the month: 12
- Number of versions to retain before applying the above settings: 10
Using these settings, the following apply:
- Because the backups only run once per day, the Number of hours to retain the latest version of the hour setting does not apply.
- From 1/1 to 1/10, because the total number of versions backed up (10 total) does not exceed the specified number in the Number of versions to retain before applying the above settings setting (10), all backup versions are still retained during this period.
- After 1/10, all the other settings activate.
- Let's suppose that the backup schedule continues running until the end of the year 2024.
At the end of 2024, we will have the following versions retained:- 7 daily versions, one for each of the last 7 days
- Versions 12/25, 12/26, 12/27, 12/28, 12/29, 12/30, and 12/31
- 4 weekly versions, one for each of the last 4 weeks
- Version 12/15 for the week of 12/9–12/15 (Note: Monday is the start of the week.)
- Version 12/22 for the week of 12/16–12/22
- Version 12/29 for the week of 12/23–12/29
- Version 12/31 for the week of 12/30–12/31
- 12 monthly versions, one for each of the last 12 months
- Version 1/31 for the month of January
- Version 2/29 for the month of February
- Version 3/31 for the month of March
- And so on...
(That is, for each month, the version created on the last day of the month is retained.)
Použitelné produkty
Hybrid Backup Sync (HBS 3 verze 24.0 nebo novější)
Hyper Data Protector (verze 2.3.0 nebo novější)
NetBak PC Agent (verze 1.3.0 nebo novější)
Podrobnosti
V Hybrid Backup Sync (HBS 3) Chytrá správa verzí funguje tak, že vytváří pravidelné zálohy a uchovává je po stanovenou dobu. Při konfiguraci Chytrá správa verzí musíte nastavit časová období pro několik různých nastavení.
| Nastavení | Popis |
| Počet hodin pro uchování nejnovější verze hodiny | Nejnovější záloha vytvořená v dané hodině se stává hodinovou zálohou. Záloha je uchována po stanovený počet hodin, než je odstraněna.
Poznámka Toto nastavení se nevztahuje na HDP. V současné době HDP nepodporuje hodinové uchovávání Chytrá správa verzí. |
| Počet dní pro uchování nejnovější verze dne | Nejnovější záloha vytvořená v daný den se stává denní zálohou. Záloha je uchována po stanovený počet dní, než je odstraněna. |
| Počet týdnů pro uchování nejnovější verze týdne | Nejnovější záloha vytvořená v daném týdnu se stává týdenní zálohou. Záloha je uchována po stanovený počet týdnů, než je odstraněna.Poznámka Pro toto nastavení začíná týden v pondělí v 00:00. |
| Počet měsíců pro uchování nejnovější verze měsíce | Nejnovější záloha vytvořená v daném měsíci se stává měsíční zálohou. Záloha je uchována po stanovený počet měsíců, než je odstraněna. |
| Počet verzí k uchování před použitím výše uvedených nastavení | Toto nastavení určuje minimální počet verzí k uchování před aktivací jakéhokoli z výše uvedených nastavení. Toto nastavení vám pomůže zajistit, že když je hodinová, denní, týdenní nebo měsíční záloha odstraněna na konci stanoveného období, systém nezůstane náhodou bez žádných záloh. |
Poznámka
Pokud je frekvence plánu zálohování vyšší než období nastavení, pak se toto nastavení neuplatní. Například, Počet hodin pro uchování nejnovější verze hodiny nebude mít účinek, pokud je plán zálohování nastaven na Denně, bez ohledu na to, jakou hodnotu pro toto nastavení určíte.
Například si představme, že jsme naplánovali zálohy na denní běh ve 3:00 ráno od 1. ledna 2024 a nastavili jsme Chytrá správa verzí nastavení následovně:
- Počet hodin pro uchování nejnovější verze hodiny: 24
- Počet dní pro uchování nejnovější verze dne: 7
- Počet týdnů pro uchování nejnovější verze týdne: 4
- Počet měsíců pro uchování nejnovější verze měsíce: 12
- Počet verzí, které se mají uchovat před použitím výše uvedených nastavení: 10
Při použití těchto nastavení platí následující:
- Protože zálohy se provádějí pouze jednou denně, Počet hodin pro uchování nejnovější verze hodiny nastavení neplatí.
- Od 1/1 do 1/10, protože celkový počet zálohovaných verzí (celkem 10) nepřekračuje specifikovaný počet v nastavení Počet verzí, které se mají uchovat před použitím výše uvedených nastavení (10), všechny zálohované verze jsou během tohoto období stále uchovány.
- Po 1/10 se aktivují všechna ostatní nastavení.
- Předpokládejme, že plán zálohování pokračuje až do konce roku 2024.
Na konci roku 2024 budeme mít uchovány následující verze:- 7 denních verzí, jednu pro každý z posledních 7 dnů
- Verze 12/25, 12/26, 12/27, 12/28, 12/29, 12/30 a 12/31
- 4 týdenní verze, jednu pro každý z posledních 4 týdnů
- Verze 12/15 pro týden od 9/12 do 15/12 (Poznámka: Pondělí je začátek týdne.)
- Verze 12/22 pro týden od 16/12 do 22/12
- Verze 12/29 pro týden od 23/12 do 29/12
- Verze 12/31 pro týden od 30/12 do 31/12
- 12 měsíčních verzí, jednu pro každý z posledních 12 měsíců
- Verze 31/1 pro měsíc leden
- Verze 29/2 pro měsíc únor
- Verze 31/3 pro měsíc březen
- A tak dále...
(To znamená, že pro každý měsíc je uchována verze vytvořená v poslední den měsíce.)
