How can I fix high CPU usage issues when using my NAS with a Samsung DLNA/UPnP TV?
Applied Models:
Answer:
Using a Samsung DLNA/UPnP TV to access multimedia content stored on an entry-level NAS model may sometimes result in high CPU usage.
To resolve this issue:
  1. Log on to the QTS web console.
  2. Go to App Center > Entertainment and locate Media Streaming add-on. Click Install.
  3. Click Open.
    The Media Streaming Add-on page opens on a new window or tab.
  4. Go to Media Receivers.
  5. Locate your Samsung TV from the device list and then click Edit .
  6. Select Auto detect and then click Apply All.
The system automatically adjusts the streaming format.
Datum vydání: 2017-01-16
Bylo to pro vás to užitečné?
Děkujeme vám za vaši zpětnou vazbu. Máte-li nějaké dotazy, kontaktujte prosím adresu support@qnap.com
40% lidí si myslí, že to pomáhá.
