After using a Mac to format a USB Hard Drive, QGenie (QG-103N) only recognizes a small volume. How do I get it to detect the full space?
Applied Models:
Answer:
QGenie will only recognize and mount the “first partition” on external drives.
When performing a full disk format, a Mac will create another small volume. So QGenie will recognize that small volume instead of the main partition.
You can format a single-partition drive by selecting the “Master Boot Record” format in “Disk Utility”. Or you can use a Windows PC to perform disk format operations instead.
Datum vydání: 2016-02-24
Bylo to pro vás to užitečné?
Děkujeme vám za vaši zpětnou vazbu. Máte-li nějaké dotazy, kontaktujte prosím adresu support@qnap.com
33% lidí si myslí, že to pomáhá.
